dae06
- March 25, 2009
- Minnesota
- ranger-1991 and 1995
I am looking at buying a 1997 Ranger with the 4.0 liter V6. The seller tells me it needs an intake manifold gasket replacement. I've talked to 2 mechanics in my area for quotes for replacing this. I've read many great threads here and have some confusion.
Both of the mechanics I talked to said I need to replace the upper, lower gaskets along with the valve cover gaskets. I don't remember reading anything about the valve cover gaskets needing to be replaced for this procedure. They both said I need an oil change and coolant flush when doing this. I guess that makes sense to me.
Also, One mechanic said the gasket set was either $90.00 for one set or $130.00 for the better set. I've seem prices on this site that were more like $35.00 to $50.00 for the set. What's up with that?
Am I missing something or are they wanting to fix more than is needed.
BTW, none of these guys have seen the truck, I just asked them for prices to replace the Intake manifold gaskets.
