How to: Pull trouble codes on 4WABS, very simple | Page 3 | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
I don't know if this will help or not because it is for a 1994 Bronco, but it should be similar. Can't yet find the Explorer info but when I do, I will post that.
http://www.fullsizebronco.com/forum/showthread.php?t=86620
Some good info and the link works...I will add this I disabled the ABS about 2 years ago pulled the 30 amp fuse...I didn't like the pulsing on hard stops...naturally the ABS light came on and went off when the fuse was put back in 2 years ago...Now 2 years latter the light wont go off with the fuse in and the fuse is good???
So why bother now, I had a transmission rebuild and I'm having trouble with TTC lock-up. The trany is slow to release lock-up and will not release lock-up when you hit the brakes. What I read the TTC gets it's info when to lock and unlock form the computer.
I read it's supposed to unlock when you touch the brakes. So my thought is the computer is not getting information from the ABS to send to the TTC...Just a theory???
Anybody now for sure...
Thanks for the help
Bruce
Can someone re post the pics i dont know what pin e looks like
ABS Connector
Hope this helps smegun.
I did a Google search and found the connector:
images
Try this info
If that pic didn't help, try this video that bruce119 posted to youtube:
OK I'm going to add photos & video to this thread...I have a code 17 need help with that...
I had an ABS light on so I took photos and video
Hopefully it will help someone and someone can help me...
The connector is located here
Here the cap is off and I pulled it away for easy access
Here I have jumpers and test light hooked up my test light didn't work so I used the dash ABS light
Here is the YouTube video that shows my codes..
https://www.youtube.com/watch?v=fb__HhmDli0&feature=em-upload_owner
Hope it helps someone and someone can help me with the code 17...
Thanks
Bruce
which pins are what? I cannot tell by my connector.
Since bruce119 covered 4WABS, I figured I'd make a video for RABS on the 1991 and 1992 model years.
Photos & video
Thanks
Bruce
I have a 94 Limited edition Explorer and the ABS light is always on. It did not flash at all. Is my ABS module faulty? Is it easy to replace? Or am I doing something wrong?
