How to Remove my Door inserts?? HELP!! QUICK | Ford Explorer Forums
vlvyvzxlt
Perth, WA
1998 XLT
how do i remove each door insert on all my 4 doors in my 1998 ford explorer??
i need to get the the speakers. to be able to take them out and install my new ones. any links or pictures or information would be great.
cheers
welcome to the site, you just pull on it, it pops off
If you're going to remove major pieces of interior trim, it's best to heat the interior of the truck first; this makes the plastic soften slightly and will help prevent possible breakage.
Many of the attaching screws and pins are hidden by plugs, caps, etc. or are the attaching point for clips or brackets. The plugs and caps can be removed with light prying action. Don't force anything-if the trim isn't coming out, it's because you've missed a screw somewhere. Most attaching hardware is located around the perimeter or near the center of the piece. Don't forget to reinstall the ornamental plug or cap that hides the screw when the part is back in place.
Also, some moldings cannot be removed without first removing the adjacent molding. It may seem like more work than necessary, but if you force something that isn't meant to come out yet, something is bound to break. If seat belts are in the way, refer to that section for proper fastener torque values.
