How to replace front driverside U-Joint | Ford Explorer Forums
92expsu
hazleton PA
92 explorer
How do I get the left shaft and joint assembly out to replace the u-jointon a 92 explorer 4.0 pushrod? :us:
92expsu said:
How do I get the left shaft and joint assembly out to replace the u-joint on a 92 explorer 4.0 pushrod? :us:
Is it that hard to replace
Do you have a manual? As I recall, Chiltons/Haynes both do an adequate job of describing how to pull the axleshafts out. Basically, you remove the wheel, rotor, spindle, and the axleshaft just pulls out.
