- January 26, 2004
- Mechanicsville, Virginia
- 2004 Acura TL
I am planning on designing my front driveshaft to use a driveshaft with a u-joint on both ends instead of a u-joint and a cv-joint (bowl) style on the other end - and the front driveshaft I have is from a '95 Explorer. It has a double-cardan yoke and a single yoke at the t-case. Now, the slip joint in the middle is sealed (no grease fitting) and the boot is dry rotted -- can you replace just the boot? Any help would be nice.
-Drew
ps - if you have a old driveshaft that has a slip joint boot that you do not want - please PM me as I will pay you for the boot. Also, I will need measurments: length and size of holes (I believe they should be different at each end of the boot). Thank you.
-Drew
