how to tell if you have posi traction | Ford Explorer Forums
ckomai
Long Beach,CA
1991 Explorer
Is there a way you can see if you have a limited slip differential without jacking it up and testing it? I heard you can check the axle specs on the side of the drivers door and if it has a D4 then you have it. Is this true?
got it, i have open diff with 3.55 gears. Thanks
Yes the D4 axle code on the door tag means you have the trac lock differential that ford has been using in cars like the torino cobra jet and mustangs. I love this rear end. Im glad mine came with it. Its enough for my uses.
