poolsexpo
- September 19, 2014
- 99 explorer ohv
I'm a little unsure on how this truck is acting. I do alot of research on the Explorer, and most of it comes from here which is a huge help. I have a 99 Explorer, 6cyl ohv, 2wd auto with about 153,000 miles. The issues I'm having are lately when I go to start it, it is cranking for about 10-15 seconds before it fires, in which once it fires, it's stumbly like it's lacking air or fuel. It stumbles for 5 seconds than goes to idle like it should. I recently have also been dealing with a electric issue about same time this started. When turning key to start, starter goes real slow like weak battery. I bought new battery and had it charged. Then I removed starter and cleaned it up, sanded all contact's and grounds then put it back on, pulled ground cable and supply cable and cleaned the ends. Put new terminals on battery and had alternator checked at 3 separate places. Same slow turn over. Once started the battery gauge is in normal place. Besides those two minor issues, the truck seems to have a very very slight misfire or shudder every I'd say 30 seconds. I am meticulous about my vehicles, I keep up with everything. For what it's worth, since the possible misfire, I have done new Motorcraft plugs gapped to I believe. 58? Whatever the minimum gap is recommended I went a few above it. New wires, filter, seasoned, Trans fluid and filter change, upper and lower intake gaskets about 8,000 miles ago. New pcv valve, iac valve, dpfe sensor went out and blew a hole through intake so the hole has been filled and patched.
