HP brake rotors | Ford Explorer Forums
HP brake rotors
aldive
Elite In Memoriam
1999 XLT
Are there any advantages when using slotter rotors or those with holes in them?
Slotted or otherwise “ventilated” rotors are better then stock rotors. Basically, they run cooler and grip harder. If your not racing your truck, I personally don’t see the benefit of a $300 plus outlay. Some may argue with me on that but it’s just my 2 cents. Stock breaks, assuming they are in good condition are adequate for most driving conditions we will face. But, slap a supercharger on you truck, lower it and go import hunting and you may very well need to upgrade the breaks. I have been looking into a breaking system that cost a tad over $2400.00. You can go nuts on this stuff. But to answer your question, yes, there is an advantage to using slotted or drilled rotors but only you can tell if the cost is worth it.
Brake system.
What is the $2400 brake system you've been looking at? What does it include? I've been looking for a kit with larger cross-drilled rotors and better calipers. Let me know what the web site is. Thanks.
I was referring to Baer. They have several brake systems to choose from. They quoted me about $2400 for a complete brake system including 4 four piston calipers, 4 drilled rotors and stainless steel lines.
Dead Link Removed
Go to Dead Link Removed and check them out. They respond quickly to e-mails.
