Hey guys,
I just purchased a previously owned non-amped HU and CD Changer for my 95. I thought it would be a quick plug and play job, but it is not working out that way.
First, the black plugs on the back of the HUs are slightly different between the two. One uses slide notches at the very edge of the plug, and the other has slide notches slightly to the center of the plug. I believe this should not be a big deal b/c I should be able to just shave the slide notches, and it will plug right in. Anyone know if I am asking for trouble by doing this?
Second, I can't figure out how to hook up changer or even if my X is pre-wired for a changer. The changer has a 12 pin female plug on the side of it. The only harness plug I can find in or under the console is a 8 pin (network cable looking) female plug mounted inside the console. Is there an adaptor cable to go between these two points, or is this plug in the console for something else (looks like on of those old car phone jacks).
Please help and ask any questions you need to help. The truck is here and console is torn apart and I have digicam to take any pics that could help.
Thanks,
Robb
Thanks,
Robb
