fouroh
- July 13, 2001
- Dracut, MA
- 2002 Explorer XLT
I looked at the sticky but it doesn't say anything about the 02+ Explorers. I am going to upgrade the system but I'm not sure if I have an external amp. The deck is AM/FM/tape/CD and I don't see a sub in the rear. Could you get the 02+ with a sub like the pre-02 models? I don't have the 6-disc in dash if that matters. I plan to replace the deck, speakers, and add two amps and a sub. The rear speakers will likely be run off the HU so I need to know if I'll need to bypass a factory amp or anything.
Also, how do you remove the stock deck? This doesn't have the holes to use the U-shaped tools on, so do I just pop off the plastic trim panel?
Thanks
Greg
Thanks
Greg
