hub replacement | Ford Explorer Forums
hub replacement
99stocksport
Clemson, South Carolina
'99 Sport 4x4
well yesterday the right front hub went bad because of a bad bearing...the shop charged me $430 to do the repair. they claimed that the parts for this repair cost about $330. i was wondering if this sounds about right?
thanks
Davis
That sounds in the ball park in my area. Front hub from local parts store is something like $225-250 but your shop is going to have to have some markup to pay the bills.
Had one local place quote about $800 to do both but that also included a lifetime warranty on the hubs
Ditto. $200-$300 for the part and an hour to an hour and a half of labor to install it.
That sounds accurate...
DeRocha said:
That sounds accurate... autohubs are very $$$ and cost double that of manual hubs.. Most members swapped to manuals since its cheaper and manuals are many times stronger than autos... Autos are fine for normal on-road - lite wheeling, but they will eventually break if you really stress them (as in moderate + wheeling).
The hubs he's referring to on a '99 are completely different than the hubs on a 93.
-Joe
-Joe
Sorry my bad... You are 100% correct... I have edited my post to indicate my error.
Not a problem.... we've all done it. :)
do you need to change the hubs as well, if you're only changing the wheel bearings on a 4x4?
The front wheel bearings on a 2nd gen are a sealed assembly referred to as a 'hub'. The 'hub' on a 1st gen vehicle is what locks and unlocks the wheel from the axle assembly.
So, to answer your question, if you change the wheel bearings on the front of a 4x4, you ARE changing the hub. They are one and the same thing.
-Joe
alright thanks for that info.
I did one hub on my 98 AWD three years ago. The hub was $205 from F.ord then.
