Hub/Tranny issue? Help!? | Ford Explorer Forums
Jester1994
Franklin, MA
'16 Explorer Sport
Hey guys, I recently drove 2500 miles from MAss. to Idaho in June and just made the return trip from Idaho to Las Vegas to Mass., 3300k last week. On the way out, 3-4 times, just cruising along, the tranny would pop out of drive and the engine would rev up, like it was in neutral. To correct this I had to put the tranny into neutral for few seconds then back into drive and it would catch again. It did this same thing, but more frequently on the way home, also, 50% of the time on the way home when it did this, the check engine light would pop on thent he explorer would stall! While I was going 75mph down the highway. I had to put it into neutral and turn the key all the way off to get it started again. I think it might be a computer control problem with the tranny? celinoid? Any ideas?
Also, there is a litlte vibration in my front end, under my feet every once in a while, some friend though it could be one of the u-joints starting to go? Ideas?
Thanks!
Have you checked the fluid level in the tranny?
Ya, the fluid level should be ok. My Explorer is actually getting checked out today, so I'll know for sure.
