Hitchhikingmike
- January 21, 2008
- Dallas, Texas
- '02 XLS
I have been running a Hayden fan controller 3647 with the adjustable thermostat with my taurus electric fan setup for two months now in the peak of the summer heat. Now all of a sudden it only works intermediately.
I verified that the controller relay works. I tested the relay socket on the controller with a voltmeter and verified that no signal is being sent to the relay to turn the fans on when they should be on.
My wiring is correct and the efan has its own relay so it is impossible for the fan to draw too much current past the controller's rating.
I am wanting to know if anyone else has had poor luck with hayden fan controllers or if they recommend any better controller.
Right now I just have the relay on my e-fan plugged into the ignition wire so that the fan just stays on all the time when the key is in the ignition.
