I finally have a snorkel | Ford Explorer Forums
Caracas, Venezuela
2000 Sport
I´m so happy now that i finally instaled my snorkel......i used a fyber glass snorkel and i change the intake air box with a conical k&n filter
hope you like it i will put some more pictures later
http://*********.20m.com/images/snorkel latfron.JPG
http://*********.20m.com/images/filtro de aire.JPG
(You have to Open a New Window and then Paste The URL in that window.....)
Hope you like it
:D :bounce:
if the pictures dont show right click them and copy the http adress and look them directly from the browser....sorry about that
looks really really nice. So now is all the air coming in through there?
Looks very nice. How long did it take you to install?
yes OK89 all the air is coming in through the snorkel......it kind of runs better because it increases the ir flow......
Jason-25 it took me around 7 hours to install it, i had to take all the fender off, take the radio antenna out, and find out where should i make the hole, then i did all the conexions with pvc plastic pipes and i change the airbox with the conical filter...... 2 friend of mine help me do it....
i also was wondering if you know if i have to seal any other part in order to go deep in water...... i extended the transmition hose but i don´t know if i need to do something with the computer that is located on the fire wall?¡?¡?¡ any suggestions '¿'¿'¿
Make sure to do your front and rear axles also.
I recommend just covering the computer in vaseline.
