I have a problem with my A4LD transmission. | Ford Explorer Forums
dave ramsey
Kalispell,montana
91 eddie bouer
have transmisson problem.won't shift with out letting off throttle.no slipping shifts from third to overdrive fine. anyone have idea? thank you
Welcome to this forum! I've renamed, and moved your thread to the transmission section. It sounds like you might have a broken band, an out of spec band, out of adjustment kickdown cable or a leaking modulator. Check the fluid level, and adjust the bands first before taking any parts out.
