JoeStlroyals
- August 25, 2011
- St. Louis
- 94 ford explorer
Ok SO I have been using this forum to help me find out how to do things with my explorer for some time now. But I am at the end of my rope. Here is the Story....
Fuel pump went out in early April had it replaced at local shop. I experienced the same symptoms as before only and took it back to the shop to be warrantied. They fixed it. Happened again, then again, then again, and then again after the last time they fixed it and said that they will no longer be warrantying it and returned my money.
It ran fine for about 2 weeks then I started experiencing problems with it again. But the fuel pump is working fine. Then engine gave me a code that said the ignition coil was bad so replaced that. Worked for a bit, then similar symptoms checked code, said ECT sensor replaced didn't fix, then got MAS code, replaced didn't fix, then got, O2 sensor reading replaced both fixed the idel issue but still not able to run correctly.
I am at my whits end what is it, what info do you need from me I am about done.
