Desibean
- February 9, 2022
- Evansville
- 2003 Ford Explorer LTD AW
I'm sure I don't have to relay to anyone the myriad of issues I have had to fix in the few years I've had this truck. But I'll start with the most recent because it just occurred for the third time in as many years, yesterday. The truck would not shift out of park. After a few minutes I'm trying it eventually did and I drove to my local gas station because that's where I was going. Same issue when I get ready to leave. I knew from prior instances to check the brake lights, by myself so did this w/ an umbrella. It was intermittent, about every one out of three times I pressed on the pedal the brake lights would come on. When it finally did it two or three times in a row I figured that was my chance to hop in and get home. We have snow on my street so I'm able to see the lights much better from the driver's seat. So I press on the brake pedal and the brake light comes on but then immediately goes off. So this time I depress the pedal all the way down and it stayed on for several seconds and then went off. Next time a little less pressure but still pressing the pedal and it stayed on for longer. So I know it could be a solenoid issue or brake switch issue but if that were the case would it be intermittent like this? Again, it's only happened a handful of times over a span of a few years so what would make it work for several months on end and then all of a sudden start this up again? Is this normal behavior prior to something going completely on the fritz? Any insight is helpful because I'm not sure where to start...
