Yeah, the ford fans move alot of air. Your main concern is space. The big single fans(mark VII, taurus) have to have their shrouds depth trimmed down to clear the water pump stud because the fan motor is lined up with it. A lot of guys have used dual fans out of a ford contour. They move about 3500-4000 cfm which when coupled with a good controller is more than enough for your V8. I am using the contour fan in my V6 because I have the original dual core radiator and the dual fans end up above and below the water pump stud. There are also guys who use after market fans(flexalite, spal, blackmagic, etc). It's really personal preference and how much you want to spend. those after market fans can get pricey. The other expense is the controller. There are a few to chose from here as well. The major players are Delta Current Control, Spal, and Painless Wiring Products. Again it comes down to what features you want and also price. My personal preference is the ford fans. They're durable, plentiful and cheap. Got mine from the u-pull it for $15. My buddy got his for $20. Do you research, ask questions here on the forum. There's a bunch of guys running e fans. Search electric fan conversion and you'll come up with a ton of info. Good luck and if I can help just ask.
