I need another 1" of lift after the F150 spacers | Ford Explorer Forums
kidd666
reno, NV
'94 xlt
how could you get another inch or so of lift in the front after f150 spacers?
1.5" skyjacker springs. I don't believe there is anything else unless a bigger spacer in the first place
Add some washers under the spacer.
Keep in mind you may already be pretty close to maxing out your ability to properly realign the camber & caster. Once that happens, you'll need dropped brackets to go any further.
The other options are a body lift (2" or 3"), or an actual suspension lift kit.
