89Fox
- April 10, 2005
- St. Louis MO
- 1995 Explorer Eddie Bauer
OK... about 6 months ago, the drivers side motor crapped out so I replaced it and everything was fine. Today, the front drivers window went down but wouldn't go up. All of the other window work up/down from drivers panel. In addition, the doors will lock but now won't unlock from master driver's switch. Passenger side will lock/unlock door. All other window switches in car are functioning properly. Sounds like the master switch is bad? Do you guys concur this is most likely my problem? If so, how much do they cost cause I'll probably run and get one tomorrow.
Thanks in advance.
Thanks in advance.
