help same issue
ok guys im new to this and i need some help if you could
i got a 00 explorer 4.0 4x4 with 120,000 miles i recently bought.
my problem is when put in drive it will stall out violently but when put in reverse it will work, i got this truck to move in 4 low a few times after slamming it in drive with some rpms. I unpluged a few sensors on the tranny and got it to stall in reverse also. I just want to know how to determine if it is a sensor or if the tranmission is junk. i was told that the tcc could be the problem but im not really sure. when checking the sensor i could see i tested the transmission range sensor for continuity but only got one out of three to work (neutral) . i need some help so anything guys
ok i got some codes off my truck i need some help guys
po708 trans. range sensor input high
po743 torque convertor circut malfuntion
po755 shift solenoid b, c , d malfunction
should i change all solenoids going bad ijn the tranny ,
isnt that all the sensors in the tranny?
should i check relays i got 15 days to get this sucker on the road
thanks .
i cleared the codes got it to drive and got this code po320 ignition / dist engine speed input circut malfunction
