I need some help. | Ford Explorer Forums
I need some help.
danawanaye
North Carolina
02 xlt 4wd
I on my way back to nc from Memphis. I had to stop and check the back tires because it was driving like a had a flat tire. The 4 time I stopped was because it started jerking from side to side and it felt like it was coming from the back passenger tire. When I stopped on the next ext I came too, it was making a strange noise and I could hear the gas sloshing around. I have to wait until later this morning to get it looked at but iwas wondering if I could get some help so that i could be slightly prepared and can know a little more about this. Anyone else have this issue or know anything about how much it will cost?
Check to see if the end link(tie rod?) has come loose. Another member had a similar problem a while back. Jack up one tire at a time and try to wiggle the wheel. If it moves, observe if anything is loose and if nothing is, then you may have a bad wheel bearing.
Loose lug nuts. Start simple right?
