roboman
- June 17, 2010
- Michigan
- 2003 Ranger 4.0L FX4
1999 4.0 SOHC with automatic 4x4
There's been a slow, constant drip on the driveway under the hood area for the last two months and if it were summer, I would've crawled under right away, but I didn't so I finally checked it out last week since the weather warmed a bit. The drips on the cement were dark brown and smelled like motor oil, so when I crawled under, I was looking all over the block with no avail. Then I found a trail of wet grease along a silver unit. I don't quite know what it is though, but it looks like something involved with the 4x4 linking the front wheels. Or is it the differential? I'm a newbie so cut me some slack.
Taken behind the RF wheel:
Also behind the RF wheel; zoomed on the link between the silver unit and a drive shaft (which you can see has oil on it too):
In front of the RF wheel, taken under the bumper:
Oh, and maybe it's worth mentioning that a year ago, I had very similar drips but needed the oil changed within a week so I had them check it out. They said the pinion steering fluid was filled WAY past the proper fill level, thus was oozing through the cap. They drained it down to the right level, and no more drips.
