i would like to ask a question | Ford Explorer Forums
cockeyed
va
93 ranger x cab 4x4
am
i in the right place to ask a question about a problem with my truck
Go ahead and ask if you cant get your answer here, Im sure you will be pointed in the right direction
Welcome aboard, by the way
thanks i have a 93 ranger stx 4x4 i have new ball joints ,a arm bushings sway bar links. there is a loud clunking noise under drivers side floor bd.almost sounds like a coil spring popping sound but also has new springs also. popping noise when pressing the brake and letting off mostly very low speeds
I really wish I could help you I have a 2wd 94 that is doing the same thing I have crawled all over that thing and havent found anything. I am going to start checking body bbushings next. It is enough to drive me nuts, but with 223,000 miles I expect some moans and groans from it.
Check the radius arm to beam bolts. They need to be 2 arms, 2 legs put your back into it tight.
Most likely the bottom bolt.
thanks i will check these item today my truck is a lift at work, the noise is getting worse ,i even turn the coil spring thought it was not seated right.
