Idle Air Control Valve | Ford Explorer Forums
smoke74
Ontario
2003 Explorer Limited
Help!!! My 2003 Limited kept stalling out, I replaced the IAC with A Standard Motor Product valve. Vehicle ran awesome for a week(about 500kms) then i started getting a foghorn noise and fluctuating rpms with a couple stalls. Noise stopped when I removed the plug on valve which got me thinking the valve was nfg. I replaced the iac with another Standard Motor Product one today with same issues except a higher rpm, that goes up and down with no one behind the wheel. A friend told me to spend the money on a motorcraft iac, could this be the problem or is there an underlying issue. Any info would be appreciated
This is a common problem and yes, spend the money on the motorcraft part. It's worth it.
thanks, hopefully this will solve the issue
