ChevelleStang
- May 3, 2016
- NC
- 2003 Ford Explorer 4.6L
I have a 2003 with the 4.6l engine. I was having an odd sound (sounded like a thump in the airbox) that I could hear inside the car and a weird idle. So I looked through all the vacuum lines and have not noticed a leak. So I decided to go ahead and replace the IAC valve. So it fixed the odd sound that I was having (I have no idea what was wrong with the other one) but I now have a totally other problem that I think is all related.
The issue now is that when I crank the car (cold) it tachs to about 2,000 rpm and holds and drops a little over about 20 seconds. Once it gets to 1200-1300 rpms, it then starts to rise slowly to about 1800 rpms and then completely drops to 750-800 to normal idle. Its so weird. It does this all in about 30-35 seconds. It was not doing this before I changed the IAC valve. Also, when the car is warm and I crank it, It tachs to 2800-2900 rpms and stays there for about 5-7 seconds and then drops completely very quickly back to normal idle. I cant say for sure that the high idles at start up only happen that way when cold and hot, I think its sometimes random. But majority of the time when starting it falls in the above reference.
Heres the other issue I need help with - this is also happening because of the new IAC. I will be driving down the road and coming to a stop light and the car wont tach down to under 1000 rpm, it will stay at 1500 roughly and will "hard down shift" and wont tach down to a normal sitting idle until the car comes to a complete stop. Literally have to stop fully to bring idle down. Then the car is fine. But it is tough to stop because it is tached up a little and still wanting to pull the car.
Can anyone help me troubleshoot what to look for and do? The old IAC valve had a little rough idle, car shook at idle, and had that weird airbox noise. The new IAC valve fixed the airbox noise but added in a whole new set of issues with high rpms at start up and the high rpm when coming to a stop.
The only odd thing I have noticed is that when taking the hose off the PCV valve, it has a really high amount of suction. I cant say that's a problem but it seems to be much higher than other cars ive worked on. Also the hose that runs from the PCV to the intake looks collapsed on the curve bend that connects to the intake. Almost as if it has to much suction and is closing off the hose. But if I pull the end of the hose off at the pcv valve, it is still pulling plenty of air. Could this be an issue? Is it possible for the system to be sucking too much air?
Also, Mass Air sensor is clean and working properly. New Air Filter installed too.
Sorry guys, im totally lost here. Thanks for helping!
