zerokool
- October 26, 2010
- NWFL
- 03 Limited
So I've developed an idle surge problem. It will happen both while coming to a stop and sitting with the truck park idling, randomly. While sitting, the idle will drop enough for it to almost die, then pick back up. This doesn't happen all the time, and I'm not having any issues while moving. Cruising down the road, it runs perfect. I've read through some threads and found that it could either be a failing fuel pump, fuel pressure regulator, pcv valve or hose, or tps sensor. I'm not getting a check engine light. I'm 03 cable driven throttle body. Anyone have this problem and solved it? I know I can test the fuel pressure and have seen some info on testing the tps, but if anyone had this problem before that could point me in the exact direction, it would save me the time I don't really have to diagnose it.
