BCosta
- April 28, 2020
- Brooklyn
- 2006 Mountaineer 4.6 V8
I need the forum's help with making a decision. Money tight, I'm looking for quality on budget if that makes sense.
History. Bought with 149k, accel coils replaced with a set from 1 A on here, and E3 plugs installed.
209k now. Swapped old Accell when i had a misfire. Three months later> multiple misfires.
I have a set of Motorcraft Plugs & set of AC Delco DG 508 Ready to install.
I get conflicting information when searching multiple vendor sites. Ford Site Shows DG511.
- some vendors show one part #, others show multiple part numbers fitment.
-when Searching the AC Delco DG511's on Amazon.... First Coil Comes up AC Delco DG508. (thats how i ended up with them)
I came across DG521 as fitting
-DG521 research shows same exact as DG511, but with slightly longer brown boot.
Did motor change from '06 to '08? On some sites, the DG511 show from '08-10 only.
They are also $60 bucks cheaper per set
I would like to stay with AC Delco or close to OEM. No $30 per set.
Could i use the 508's in place of 511, or use 521 as same coil(straight boot)
Thanks in advance.
Thanks in advance.
