DJ94
- August 8, 2006
- Magalia, California
- 1994 4 Door 4WD
I have a '94 4 dr 4wd with an ignition switch problem. I have replaced the part on the steering column and the key switch still does not work. I did a shade tree fix with a wire from the relay to a switch inside the cab; wondering if anyone else has had the same situation.
There is some adjustment to the part on the steering column I guess, anyone have any ideas?
With my push button switch the car starts every time as long as I turn the key all the way.
