MrShorty
- December 27, 2001
- Spanish Fork, UT
- 92 XLT and '87 Bronco II
Decided I wanted to check my engine timing for fun. Disconnected the SPOUT connector (little connector with pink wires next between the a/c evaporator housing and the ignition coil). Hooked up the timing light to #1 (passenger front cylinder), pointed it at the timing mark, and couldn't see the 10 degree mark on the crankshaft pulley. Crawled underneath with the timing light, and there the crankshaft mark was, about 180 degrees away from the timing marker. Engine runs fine. What would cause the engine timing to be 180 degrees off? I recently had a rebuilt engine installed, is there something that they could have installed wrong that would cause the timing to show 180 degrees off?
TIA for your help.
TIA for your help.
