Improving the headlights: Brite Box Installation | Page 2 | Ford Explorer Forums
Its over a year now and there have been no problems whatsoever.
like Jefe said you can do this with a simple wire jumper :) when in HI the lows are on....simple pimple
So, when are we going to see this "Jumper Mod" ???
Improving headlights
Just go to a parts store and buy 'aircraft spotlights' as a add-on lighting system if you need 2 C better.......why tryto burn up the wiring or what have you........:confused: ...geez, some people.....:rolleyes: .if it aint broke, dont fix it!.......
:exporange :exp: :yelexp:
Wow
I would've figured for sure that you would've burnt up a bulb by now.
I've thought a couple of times about doing this with my Explorer. I've just always figured that a dual filament bulb would see a significantly reduced lifespan when running both highs/lows at the same time.
I guess not? :scratch: :monkey:
This would be a great mod for Mountaineer headlights. The lenses are much better in lightoutput than the Explorer version.
Removed the Brite Box for the installation of my new HID lights ( Installed HID lights in the diamond clear housings ).
Nothing in life is as simple as someone else makes it sound.
Yes and when the low beams are on so are the HIGH Beams. There must be a way of separateing them.
