In need of a little guidance.. | Ford Explorer Forums
navajoftw
McClellandtown, PA
1999 Explorer Sport
I have a '99 sport and love it. The front end makes about 43 different noises, big surprise right?
I know what needs replaced, I just need to know if I'm ordering the right parts. I'm almost confident that I have the right parts picked out but I just need a little reassurance, I appreciate it guys. I know I'm probably asking a lot.
The hubs, I believe I can get away with two of these, right? http://www.1aauto.com/1A/4WDrive/Ford/Explorer/1ASHF00003/
The rest I would like to get at Rockauto.com
The right upper control arm is a 2 piece so would the MOOG Part # K8710T be it and all that I need? Are there more pieces that aren't pictured there?
The left upper should just be this, MOOG Part # K8708T ?
The lower control arms I can get the SPICER/RAYBESTOS Part # 5071143 and 5071144 ?
The outer tie rods, almost positive that MOOG Part # ES3461 is it.
Again, I appreciate the replies.
anything you willing to buy used for a good price?
I'd consider it, whatcha got?
only 43 ??? I think mine made about 45 before I started replacing parts up there.Still has at least a dz up front, plus at least another dz elsewhere.
those hubs will work (nice price too,I should get myself two{whatever happened to the $15-20 bearing you just popped out and replaced ??})..
the hub/bearing assemblies,brakes,and cv axles are about all I have left to replace on mine....
at least until something else breaks:rolleyes: or the SOHC goes kaput !!
all the ball joints,control arms,tie rods etc,I just bought at O'Reilly and Autozone..
Haha, that is what it feels like
I was hoping those hubs were good, mine really need replaced. Along with the other parts. My wheel may fall off soon I've been driving on a bad hub on the right side for about two months now.
I believe there is a 1 piece Moog as well.
Rick
don't use used parts , unless you know they are good,,
you put your life in it going down the road,, and your families too
I knew there was a one piece but I'm not sure if I have to stick with the two piece or if I could get the one piece to replace the two.
