jdp12678
- March 31, 2008
- Crawfordville, FL
- 2002 XLS
I have a 2002 Explorer XLS that has approx 125,000 miles. Recently the RPM's at Idle are running around 1,200 - 1,500 during the hot part of the day, I am not sure but I believe that normal RPM at idle would be 700 - 800. This is causing some worry as I do not want the vehicle to overheat, the increase in RPM has resulted in rising temp but not redline. I replaced the radiator about 1 1/2 years ago. I know the pump is working properly b/c I can see the coolant cycling in the fill tank. Any thoughts on why the RPM are running high would be greatly appreciated.
