NoSubstitute
- November 8, 2017
- Mid Michigan
- 08 Mountaineer Premier V8
I have a 2008 Mercury Mountaineer that I was investigating replacing the radio. I took apart the dash bezel, and unplugged all the connections. I reinstalled and everything worked fine. I then took it apart again, and when I connected it again, the Info, Setup and Reset buttons no longer function. I've unplugged and re-plugged several times, and it still doesn't work. I've checked the pins, and they are all straight and appear to be making a good connection. I've also disconnected the battery and reconnected it, and still nothing. Is there some type of reset sequence that needs to be performed to make it work?
