installing oem siriusxm in interceptor 16+ | Ford Explorer Forums
mrdot
15 & 16 EXP Int. 3.5T
i got siriusxm working in a 16+ interceptor, it can be done. i'll assume it is the same though 2019. The entire fcimb (HVAC/Radio bezel) will need to be swapped. Make sure to get one very close to the made date of your current fcimb. The SW and CAL should match. I would not have been able to do this outwith CompulsiveCode - AsBuilt Explorer and a f off jmr.
parts list:
  • 16+ acm /w sat. - any sat 16+ acm will work if you understand the bits needed for with or without sync and 4.2" screen. i took one from a limited 2017 and compared a few vins to find out what is needed for base model acm's to work correctly in interceptor.
  • sat cable from lower a-pillar, behind glove box to the back of the radio, this cable is about 3 feet long.
  • fcimb /w 4.2" screen and w/ sat. If you don't have rear a/c you will need to disassemble the entire back and insert the without aux a/c lower bezel cover plate.
programming (confirmed on 2016 /w sync):
ACM 727-01-01 5800 2800 80
APIM preprogrammed option: enable sat radio/hd radio
FDCIM 7A5-01-01 2229 0408 00 (2269 0408 00 /w reverse sensors)
ACM programming 16-17 (work in progress) programming:
2016 /w SAT 4.2" screen
16-17 ACM /w sat 4.2" screen
2016: 727-03-01 14
2017: 727-03-01 2A
ACM 4.2" screen
727-04-01 0001 0255 53
I feel you have a lot of information there, but it needs clarification. You put numbers up, assuming part numbers.
Seems like cliff notes.
We could use the unabridged version. With photos are good, please.
i could careless what you do with the info. the post assumes one already knows how to use forscan, isolate bits and/or modify bits/hex calculations and has reviewed the 13-15 guide for adding sat radio. if you want me to make a youtube video ill give you my paypal/venmo.
did your bluetooth on calls work ok? I tried and everything works but my BT doesn't work for calls just is silent
yes, it works. you most likely need to adjust your new acm. save the settings as-is and then do some of the testing settings under acm above. I was having a lot of isuses until i adjusted the acm using trial and error after comparing about 15 vins.
i believe it adjusts for sync version and year.
You can more than likely skip having to pull the antenna from the donor vehicle. If the port is the same, a mini antenna would probably work and it's far easier to work with. Seen this done on a video by 4D Tech and they're pretty detailed on their conversions.
