Instrument cluster alarm/buzzer | Ford Explorer Forums
RangerSVT
Indian Mound, TN
02 V8 Sport Trac 4x4
Ok, I finally got around to doing my V8 tach mod, but when i unplugged my instrument cluster (the key was on so the shifter could be out into 1st to remove IC bezel) I started getting a series of buzzes, 5 sets of 5 to be exact. After about 5 or 10 minutes, the buzzer/alarm cycle repeats 5 sets of 5. SVT (my 96 4x4 ranger) did the same thing when I plugged in the sport trac instrument cluster. What is this, is this coming from the ic, and how can I shut that annoying noise up? I think it could be related to pats, but I'm unsure. I have pats deleted in my tuner, and I've tried reprogramming my ecu again, but that didn't work. Can anyone shed some light on this?
SVT
Five sets of five beeps is a SRS indicator lamp malfunction warning with pending SRS faults. Air bag light not working?
I disconnected my airbags when I swapped steering columns (the original shifted column for the gear selector had slack). Why did this happen only after unplugging the IC and not when i unplug the airbag? I take it this is in the IC? Any way to disable it, or will I have to reconnect my bags?
SVT
I suppose. The beeping only indicates that the lamp is out with a pending code aka your disconnected bags. If disconnecting that IC put the lamp out then your assumption is correct. I'm not up on the cluster electronics.
