Interior Lights | Ford Explorer Forums
Interior Lights
MaverickDaKid
Poway, San Diego, CA (Born in Miami!)
93 XL and 96 XLT
Ok, the lights in the second row won't turn on when I open the doors or use the keyless entry system. I however can turn them on manually.
Is there something I disabled or something? If so could someone tell me how to fix it. It's not anything that serious but I would like it if I could see in the second row when I start to get into my truck. Thanks.
OH btw its for a 96XLT and all other interior lights do work.
Check fuse, change bulb, and or pop open the lens and there is 3 screws in it, tighten them up...
The middle lights have two different sections in them. One is the lights that come on when you open the doors and the other is the ones that come on when you manually turn them on. You probably just have bad bulbs in the center light.
Thanks
I can't belive that the answer was that simple. It ended up to be a burnt light bulb in the middle of the 2 bulbs. I didn't know it had 3 in total. Thanks alot for the help now passangers can see.
No problem man. I even went out to my truck at 2:58AM (PST) to make sure I knew what the fudge I was talkin about. :D
