genesiss
- March 3, 2008
- 2002 sport trac
2002 ford explorer. Issue with truck intermittently not starting every 3 weeks to a month. When issue begins truck was just turned off then back on and it sputters and stalls like its out of fuel. I waited an hour almost to the minute and then it starts but no sooner.
1. Cleaned mass air flow sensor
2. Cleaned IAC
3. Replaced camshaft and crankshaft sensor
4. Replaced ignition coil pack
5. No codes
6. Mechanic cannot find issue, its intermittent so it never happens in the shop
Within a day of replacing the ignition pack after some stop and go came out to vehicle after resting about 30 min and it had a rough idle and puffing out light amounts of black smoke with the smell of gun power from under the hood and the a/c will not work at all. Drove it to the auto parts store and they were clueless. Drove it home and turned it off, then back on and everything works! no rough idle, no black smoke and a/c works! Clearly too rich of fuel mixture but no a/c and it all clears up on a restart moments after being turned off?
2. Cleaned IAC
5. No codes
