Intermittent grinding sound from engine | Ford Explorer Forums
mysticclam
Typo King
Tacoma, WA
91 XLT
Left a friends house really late last night and it was really cold so I was letting the x warm up before driving home. After about a minute I heard a metal bearingish grinding sound. It wasnt loud and lasted about two seconds. After another 15-20 seconds it did it again abit longer maybe 4 seconds. It went away. Anyway every 15-30 seconds after that it would do it again. This is not a loud sound and never lasted more than a couple seconds. Could this be waterpump. It seems to be from the front of the engine. After a few minutes I drove home. I could tell it was doing it all the way to the freeway then the wind and engine was too loud to hear. When I got home it wasnt doing it anymore. If it does it again what should I do to try and narrow it down. Again its not very loud and is just kind of a chu chu chu chu sound for a really short time. Doesnt seem to be any play in the water pump shaft. It speeds up with the engine too.
This is on a 91 OHV. Could this be only showing up now cause of the cold?
Clamman, did you have the defrost on?? Could be the AC Compressor?? The cycling on and off is consistant with it.
on off didnt make a difference Ive been around this truck for 13 years, so its a new sound.
The AC hasnt worked for oh, 11 years so dont think thats it. Its just like that sound a cpu fan on the pc makes when its starting to go, you know it wobles and buzzes for a second or two then is fine for awhile. As long as it doesnt get worse I think Im going to ignor it. Thats if it even does it again.
From the front of the engine? I would guess one of the many accessories driven by the serpentine belt (alternator, water pump, tensioner pulley). If it were me, I would poke around with a stethoscope to see if I could figure out more precisely where the noise is coming from.
Yeah, had a guy at work listen to it and he said its identical to what his 91 F150 did a few years ago and it was the clutch on his AC compressor. I think I may just hit the wreaking yard and see if I can convert to a non ac setup since there is no point with my AC not working anyway to be replacing parts of the system.
I win a cookie!
:D Turn the compressor into 'on board air' :thumbsup: :thumbsup:
