koda2000
- September 2, 2011
- x
if you still have your original radiator, it's probably leaking from where the plastic tanks attach to the aluminum core. look for greenish residue on the plastic tanks. you can also remove the front air deflector (4 10mm bolts) and look in there for wetness or signs of leaking. that may also explain why your not pulling fluid from the reservoir, as it will suck in air from the leak point.
