flyinthrew
- January 2, 2023
- Atlanta, GA
- 2016 Explorer Limited
2016 Explorer Limited with 125,000 miles. Shortly after putting it in park and pulling out of the spot, if you get into any sort of lower idle and add fuel it stalls. It then has a very hard time getting restarted.
I haven't put my finger on a culprit yet. It has happened only a couple times, and I cannot duplicate it. Battery and alternator both test fine on the multimeter even under a heavy load.
Is there a voltage regulator check I can do? Perhaps it's not electrical. Is there is an O2 sensor somewhere that needs swapped? What else should I check?
