cnsheets
- September 7, 2011
- 2011 Explemoner
Hope someone has had a similar problem or can provide some knowledge...
2001 Explorer Sport, 4.0 V6
Few months ago after driving to get food, we came out of restaurant to leave. Went to start the car and it wouldn't start. Sounded like it tried to fire for a split second then nothing, just cranked over with no start. To me, it seemed like it wasn't getting fuel. Fuel tank read almost 1/4 tank. Just to be safe, we ran to the gas station and brought 2 gallons of fuel back, dumped it it, nothing....wouldn't start. Called AAA for a tow. We waited about 20 minutes, just before AAA showed up, I tried to give it another go......started right up, no hesitation.....huh? So we had AAA follow us home just to make sure, car ran perfectly fine. Just to be safe, I replaced the fuel filter that same night.... Cars been running fine for the past couple months.... Then, after returning home from a 20 mile drive, parked the car...went back out 10-15 minutes later, car wouldn't start. Same problem as before.... I nosed around, checked a few things, no OBD codes, nothing apparent... 20 minutes later, the car starts right up, no problem or hesitation. Funs perfectly normal.
Took it to the dealer .... they have had it for the past 24 hours and can not duplicate the problem. Starts every time for them. Had them drive it, warm it up, park it, wait, starts right back up. No codes for them either. They put a fuel pressure tester on the rail and shows about 30Lbs without the car running, turn the key on, and while running, it shows about 60lbs. They can't get it to not start. Its done it twice now to us and we are concerned that it may cut out while driving......Going to pick it up from dealer as it is pointless to pay them to keep periodically starting it to try and duplicate the problem.
What else can we check? Suggestions??
