shrink645
- October 7, 2007
- Simpsonville, SC
- 97 Limited
I've been having an intermittent starting problem with my 97 explorer limited for about a year. It's the 4.0L SOHC. It started as happening about once a month but is now happening weekly. Basically, at random times it cranks and the engine turns over but doesn't start. Sometimes it takes 3 -4 times and others about 10 times before it starts but it always starts.
From some research that I've done here are some things that I have replaced.
1) battery, plugs, wires, fuel filter
2) IAC valve
3) PCM relay
4) Fuel pump relay
Any other suggestions would be greatly appreciated.
2) IAC valve
3) PCM relay
4) Fuel pump relay
