Hi, New to this forum. Thanks for accepting me in. I have 1997 ford explorer limited 5.0l. Having a bit of an issue with my left driver side window. It rolls down with no hesitation but, when I go to roll it up, it goes up, just "pauses" a few times while doing so. Recently replaced BOTH Driver and Passenger Side regulator/motors. Just curious if anyone else had the same issue? Thanks in advance and sorry if I'm posting in the wrong thread.
Brandon Treu
Hello Brandon & welcome to the forum!
OK - first off, I'll assume that you greased and oiled up the window regulators when you installed them.
With that assumption out of the way, I'll give this a shot based on my experience with the internal guts that make up the drivers door.
On the drivers door, the rearmost curved window track is connected very inadequately to the bottom of the door with a single rivet (if I remember correctly) through a tab that's welded to the bottom of the window track.
Because the drivers door is the primary door, the rivet & tab on the track gets beat to hell with G forces each time the door is slammed closed - especially when the window is completely rolled down. Add to it water that gets past the window and flows to the bottom of the door and as it does it corrodes the area of the window track where the tab is double spot welded to it.
Put aside 20 minutes, go back, pull off your door panel, get a flashlight, and see if the rivet has broken free from the bottom of the door, OR, if the tab that is double spot welded to the window track has broken those two welds.
The following is a print of the PASSENGER WINDOW on a '93 - '11 Ranger - but it will work for this as it's the same set-up; you're concerned with Part(s) # 5 & 6
Hope that helps & report back!
