is 88 bronco 11 parts compatiable with 89 ranger, both 2.9l | Ford Explorer Forums
victory89
collinwood, TN
I jusr purchased a 1988 bronco 11 and i have a 1989 ranger with same motor. just wondered if i could use the locking hubs on the ranger and put on the bronco cause the motor that puts the transfer case into 4x4 needs tapped every time. and also wondering if other parts will can be used
The short answer is that most parts should interchange between the two.
An easy way to find out what interchanges with what is to go to Car-part.com and do a search for a particular part.The results will give you the range of vehicles and years which interchange.Another way is to get an LMC truck catalog and compare part numbers in the Ranger and Bronco II sections.
