Is it a good idea use a line converter?? | Ford Explorer Forums
Goodfella
Canada
1996 Explorer Limited
Hello fellas, i have a 4 channel auidobahn amp, the A4400E. and i am currently runnning 2 OZ 10 inch subs in a bandpass box, this is a temporary box for now. I was wondering if i was getting the maximum performance out of my system cause i spliced into the rear speakers and connected a line converter to it, and then used a Y splitter for the RCA's in order to hook it up to my amp, i had to split it since my amp is 4 channel. I ask this since anytime I put up the volume it seems that there is a crossover and the bass is be limited some how, what i mean is, even if i wanted to, I would not be able to blow the subs i was testing. is this normal.
and also, i have the amp mounted where the factory sub and box was, the JBL equipment, and it gets pretty hot in there, i was wandering what i can use as a heat sheild to put between the amp and the trucks body, i have about ooo 3-4 inchs in between there.
also if there are anyone familar with audiobahn amps, i bought my amp off my cuz, so i wanted to know the exact specs of it, the A4400E, if it is 2 ohm stable and so on, cause it isnt too new, it does not light up blue in the window, should it? the more specs the better
I hope you all understand what im talking about, u guys are smart im sure u will, thanks a lot for any help at all.
peace and guidance
Troy
i think i know what you are talking about. the reason it sounds like there is a cross over is because a bandpass box is like a natural cross over. it limits the frquencies that you can hear. there for to fix this, you need to ttune the box to the frequencies you want. unfortunately i have no idea how to tune them.
to cure the heat problem you could hook up a fan to cool the amp.
hope i helped!
o and heres the specs u wanted
http://www.soundhabit.com/Store/product/view.cfm?ProductID=1532
PWM MOSFET Power Supply THD: 0.02% S/N Ratio: >100dB Variable 18dB Low-pass Crossover: 30Hz TO 120Hz Bass Boost @ 45Hz: 0/18dB Phase Control: 0š/90š/180š 3-way Protection Circuitry: Thermal, Short & Overload Cooling Fan Cobalt Blue Illumination High Gloss Chrome Plated Finish processors 50 watts x 4 @ 4 ohms stereo 70 watts x 4 @ 2 ohms stereo 140 watts x 2 @ 4 ohms mono Variable 18dB Hi-pass Crossover: 120Hz - 750Hz 2/3/4/5/6 Channel Operation Dimensions: 2"(H) x 12.75"(W) x 11.25"(D)
And they have pictures too!
