Blackhawk_Mech
- January 1, 2009
- Killeen, Tx
- 97 Sport 3 Door 4.0 SOHC
As somewhat of a wedding gift I was given a 2 door 97 V6 explorer sport. I knew it had previously been in an accident, however didn't think to many things were wrong with it. Since then I have invested about a thousand dollars, mostly in intake and exhaust that was a credit from the system I bought for my S-10, but never got to install.
Here is what my problem is, I have done quite a few simple things to it, but it seems like every time I fix something, something else breaks. I am not very mechanically inclined, however I am learning. What I do not have a great abundance of is time and money. Being married and in the military, I can't afford spending so much fixing a vehicle.
Here is what I have tried to do so far. Took it in to the auto bays last week to give it the best tune up I could in a few hours.
My question is it even worth trying to fix these things or should I just cut my losses now?
:thumbdwn:?
- Oil Change to Mobile 1 Full Synthetic
- Mobile 1 high mileage oil filter
- Replaced fuel filter
- Cleaned MAS, IACV, Throttle Body, battery wires / terminals
- Rotated Tires
- Checked all hoses, fluids and belts.
- Lubed everything, doors, locks etc.
- Sea foamed air intake.
- Replaced PVC valve
- Replaced radiator cap (twice)
- Changed headlights
- Added lucas fuel treatment (third application since august)
- Added lucas P/S fluid
- Reverse lights do not come on, have changed bulbs, fuses
- Hazard lights do not work
- Tranny leaks, hard to shift between 1st and 2nd. Grinds in reverse.
- Radiator leaks
- Clutch is bad
- P/S bearings going out
- Tires low on tread / Out of alignment
- Alarm was literally ripped out with random wires cut
- Very high idle, use to be around 700rpms now its at about 1200rpms
- Door locks messed up, only open a 1/3 of the time
- Headlight lenses heavily scratched/corroded. (tried everything, sandpaper and polish)
- Quite a bit of body damage
- Whatever the fuel tank capacity is, I have only got 116 miles out of half a tank driving carefully.
- Almost every screw post/anti-rattle clip is gone from behind the dash panels
