is it ok to... | Ford Explorer Forums
is it ok to...
eXploderXLT93
Renton, WA
93 XLT
is it ok to amp and amp'd signal? is it always bad? could it work? this is the only way to hook up my 4 channle and so if it might work, im goin for it, if not i will stick my thump up my ass and cry
you could, but it may screw up the signal amp.... but you could get a line level converter and then use that... that would work fine... it isnt the most efficent use of power, but unless you are running thousands of watts of stereo.. it will be fine....
ok great, how much are these new fangled line lever converters where can i get one, and is there a special type or brand that is better than the other?
they are basically the same... and are pretty cheap too... check out cruchfield or any online stereo store... heck, radioshack probably has them
