Don't bother. The 5w and 10w refer to the oil's cold viscosity, and the 30 is the oils standard viscosity. At operating temperatures, a 10w30 and a 5w30 are the same viscosity. The 5w30 is less viscous in cool temperatures or at start-up though, so it is able to lube your engine better, since it flow into smaller spaces.
Besides. The amount of wear it would take before the clearances in your engine are opened up enough to need a higher viscosity oil would be the death of your engine. That's why newer engines last longer than engines from, say the 70s, when it was ok to run 40 or 50 weight oil. Those engines had huge clearances, and wore out quickly. Think about it. If you got 100k miles out of a car in the 70s or 80s, that car was a really high mileage car. Now we think nothing of cars lasting to 200k or more.
