dcm0123
- April 6, 2006
- Hamilton, Mass
- 99&01 Sprt, 04&05 Explr
1999 Explorer Sport 4.0 SOHC 4WD
Some one set the timing up wrong in this vehicle when they replaced the main timing chain, guides and tensioner. It ran but lacked power. Found both cams timed correctly to each other but they were off about 10 degrees from crank so I need to reset the jack shaft gear.
Using OTC tool to set up timing.
Ford manual says torque bolt to 33 foot pounds then 1/4 additional turn. Says nothing about it being a torque to yield bolt.
Ford kits come with a new bolt but aftermarket kits do not.
Anyone run into this before?
